Samsung RSH1NBRS fridge freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung RSH1NBRS fridge freezer
  • #70440
    TonyMower
    We have a problem with this appliance the freezer works fine but the fridge is warm. The fuse on the main PCB had blown but changing it has made no difference. Is there some sort of diverter valve that allows coolant to the fridge or is it a sensor or module fault?
    Many Thanks
    Tony
    #378078
    Re: Samsung RSH1NBRS fridge freezer
    Which fuse ? Each connector and wire gives you what that particular wire does on a RSH1 PCB so it is a easy trace of the faulty component.
    Go back to it and look at the pcb to see where the wire goes to.Hopefully you didn’t just change the fuse and then leave it running after you left !! :eeek: for the customers sake.
    Bryan
    #378079
    TonyMower
    This is the small 20mm fuse on the main PCB on top of the appliance, the customer had already changed the fuse when we got there but had kept the old one which had definatly blown.There is only one fuse on the main board. There is a second small board that has 3 fuses on it but these were all OK
    Thanks for your advice on this problem
