Samsung Rsh5sbbp1 compressor won’t run
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung Rsh5sbbp1 compressor won’t run
  • #86049
    mbdas
    Hi I’ve been to this today and can’t get the compressor run I’ve got no power to it , No fault code comes up in the display , no earth faults so I think it’s the pcb but there are two and one with a flashing led any one got any ideas .
    Thanks Mark
    #430158
    Lawrence
    Re: Samsung Rsh5sbbp1 compressor won’t run
    look on the inside of the pcb cover there is a chart that tells you what the flashing LED means
    #430159
    mbdas
    Hi I’ve looked under the lid and circuit boards but no information sheet anywhere that would have been to easy, the led flashers once followed by a pause then repeats any ideas . Thanks Mark
    #430160
    SAMURI
    Starting Failure.
    1 Check the compressor terminals for short. ( U,V,W )
    2 Check IPM Pins short of Inverter PBA
    3 Check IPM operating voltage ( under DC 13.5V )
    4 Other cases, check the compressor cycle.
    Above is the Samsung list of faults for 1 blink Frequency
    Bob
