Samsung RSH5SBRS side by side fridge freezer fan noisy?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung RSH5SBRS side by side fridge freezer fan noisy?
  • #81473
    FlyingBrick
    Customer’s fridge freezer circulating fan reported making a lot of noise. Before I go there I do know some get frozen lumps on the housing and the blades hit the ice and have fixed it with a long thaw out for the customer over the phone.
    As I do not get involved with many Samsung units is the fan on the inside behind the semi oval plastic housing attached with two Philips screws if the bearings are gone. Anybody taken this one apart to replace the fridge side circulating fan? The fridge is reported to be 3-4 years old.
    Any help gratefully received
    FlyingBrick
    #416740
    SAMURI
    Re: Samsung RSH5SBRS side by side fridge freezer fan noisy?
    It will need a new rear panel in the fridge as the polystyrene insulation gets saturated with water and no longer insulates.
    If you defrost it it will only ice up again.
    Bob
    #416741
    FlyingBrick
    Thanks Bob
    Surprised that the insulation is of know use in only 3 1/2 years? Would have thought that the polystyrene insulation would hold up when old fridge’s run for anything up to 20 years without failing?
    The customer has had a go at taking off two screws at the bottom of the plastic panel but could not release the whole unit from the fridge?
    As I hope to get there tomorrow and will try to source the part today has it got plastic clips down each side holding it in place or contact tape when they installed it Bob.
    Flying Brick
    #416742
    SAMURI
    It is just the screws holding it on it just pulls off as it clips on the sides.
    4 screws normally 2 behind the charcoal filter covers.
    You will have to defrost it with a steamer as the cover will be frozen to the evaporator.
    Do not pull it completely of until you have unplugged the wiring connectors behind the panel and no ice is holding it to the evaporator.
    Bob
    #416743
    FlyingBrick
    Thanks Bob
    That’s a great help on a hot sunny day.
    Will go very carefully tomorrow morning warming it up to get the cover off.
    I try to stay away from fridge/freezers as the grief of the plastic and insulation snapping.
    FlyingBrick
