Samsung RSH5SHMH bleeping.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RSH5SHMH bleeping.
  • #91270
    pinch
    So, I have the above FF which has provided years of service (7 or 8 we think)
    Lately it’s bleeping with temperature lights coming on, the freezer temperature indicator has been seen cycling through from -14 to -25.
    I’ve checked the seals, they look fine, the doors are firmly closed.
    I’ve done a master reset (power off for 10 minutes or so), worked okay for a bit, temp lights off until the door is open, then on for a short time.
    The deodoriser light is on but I’m not sure if that’s linked.
    It’s currently showing temperatures then off, with no seeming pattern.
    What’s at fault here? Seals? It’s almost like it thinks the door is open, not a mechanical switch I can see though. Control PCB behind the display? Main PCB, wherever that is.
    TIA
    #447599
    pinch
    Re: Samsung RSH5SHMH bleeping.
    Well, thought I’d update.
    One of the tactile switches seemed iffy so I swapped it for one on the other side. No real change.
    Had it all apart again and put back together, all cleared. Possibly very light oxidisation of the header pins on the PCB.
