Re: Samsung Rsh7 inverter
Fault = Position Sensing Error for Three flashes.
1. Check Compressor wire connections u,v,w.
2. Check PBA bottom side soldering.
3. Check for compressor fault.
As you have low voltage it sounds like poor soldering joints on the inverter PBA.
The trouble with inverter compressors there is more to go wrong as it not just 240v as standard but the voltage veries according to demand. More to go wrong.
But a good money maker for Samsung.
Bob
