samsung RSH7UNBP ice not produced
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries samsung RSH7UNBP ice not produced
  • #90772
    Washdisher
    Attn all refrigeration gurus (and anyone else willing to hazard a guess)
    Sams RSH7 not producing ice
    Preliminary investigation shows:
    Water supply available and not frozen in door
    Inlet solenoid working
    Heater and motor on ice-maker have continuity
    Freezer temp set to -22
    What I assume to be an error code – 8 on freezer side and E on fridge side – displayed on start up. Reset by holding in top buttons.
    NB if this is an error code it’s different to previous Sams models where a segment of the display is lit.
    Any suggestions gratefully received
    Derek
    #445927
    LothianDomestics
    Spectator
    Re: samsung RSH7UNBP ice not produced
    What happens when you cycle the ice maker?
    #445928
    Washdisher
    Don’t know how to cycle the ice maker but would be interested. I fitted a replacement input pcb and have heard nothing since. Either the customer has decided to make ice manually or it actually worked.
    #445929
    LothianDomestics
    Spectator
    There is a reset button on the ice maker. Hold it down and it should chime and then run a cycle, resulting in the fins turning all the way round, then it taking in water.
    #445930
    Washdisher
    Ah yes, tried that and it did nothing – ice maker then?
    #445931
    LothianDomestics
    Spectator
    The fault you have (8E) is an ice maker sensor error. Don’t think the sensors are available on their own so you’re looking at the ice maker. Before changing the ice maker I’d make sure the 2 connections to the ice maker are in correctly and aren’t just loose.
    #445932
    Washdisher
    Hi Lothian,
    Thanks v much for your advice. Any idea where I can get the error codes for this model?
