Re: Samsung rsh7unrs water from dispenser is warm
An update for anyone thinking of buying this model. Apparently the model has a couple of recent ‘upgrades’. The motor is now an inverter motor and they changed the way and tank for the water system.
The water used to pass through the fridge in a spiral or twisty length before going into a large tank. Now it comes into a tiny tank straight from the external filter. Both the short tube and small tank cause this problem.
The samsung engineer called it a design fault and the tank the smallest he had ever seen.
