Samsung RW52DASS wine cooler not cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RW52DASS wine cooler not cooling
  • #90185
    annihilate
    I have a Samsung RW52DASS1/XEU, serial number Y1TQ4ACD700311M
    It has stopped cooling and when turned on, after a short time a click is heard, and some online searching suggested this could be the PTC relay connected to the compressor needs replacing.
    So I ordered this part:
    http://www.buyspares.co.uk/fridge-freez … ref=787486
    However, the original relay had 2 connections on it, one had 2 light blue cables going into it, the other had a single dark blue cable. The new relay only has 1 connection on it. Is this likely to be the wrong part, or is only one of the wires needed to be connected?
    Any advice much appreciated.
    Regards
    Colin
    #443973
    SAMURI
    Re: Samsung RW52DASS wine cooler not cooling
    As you hear a click after a few seconds.
    It is unlikely to be the relay faulty and more likely to be the compressor seized.
    To replace the compressor it is not a DIY or cheap repair.
    Bob
    #443974
    annihilate
    Ok thanks.
    Guess it’s time to start looking for a new fridge then.
