I have a fault on a Samsung fridge freezer.
I have defrosted the unit manually(switched off for 48hrs)
What happens is when you switch the appliance on the freezer and fridge eventually reach -18 and 5 respectively. So far so good. But then the temperature in both compartments rise although the display still says -18 and 5. If you switch the power off at the mains and then back on the display shows -5 and 17 which I think is the actual temperatures.
Anyone (R600a 😀 ) have any idea what is causing this?
Baz
