Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › samsung sg2028css cutting out
- This topic has 8 replies, 4 voices, and was last updated 19 years, 10 months ago by
bendaireboy.
May 17, 2006 at 12:44 pm #17872
bendaireboy
Participanthi people,i have customer with above fridgefreezer sn:741943cw1000w,it has an o/c thermal link in the fridge compartment,but it is also reported that once down to temperature it cuts out but will not come back on until,she turn’s m’c off at mains then turn’s back on which i believe reset’s board.now the good bit expert have been to this appliance and fitted fridge evap heater but fault still exsist’s i think thermal link problem is the cause of defrost problem but not the cutting out one ,any ideas will be welcome cheer’s nige 8)
May 17, 2006 at 3:14 pm #176766don1407
ParticipantRe: samsung sg2028css cutting out
Hi Nige
Thermal fuse is probally the cause of cutting out problem. I am sure on this model when it does defrost it waits for temp change on sensor & with fuse open circuit no heater so just sits there. Probally sensor has caused it to stick on defrost and blow thermal fuse. For this problem display on door reads normal when machine cuts out but when you switch off power and reset it reads actual temp.
IanMay 17, 2006 at 7:44 pm #176767bendaireboy
thanks don i will give it a whirl and let you know outcome next week,it was urgent now she’s away 😆
May 18, 2006 at 3:31 pm #176768expertcat
Participantnobodys perfect i must admit that i would have checked the thermal fuse.
I feel though the thermal fuse is in the wrong place.
As this happens on the new rs21.Sensor is ok but fuse o/c.
Best thing would be to replace sensor and the thermal fuse but move the fuse upto the top were the connectors are as in the original position it is strapped onto the heater.
Maybe the original fault was heater open circuit hes refitted the fuse onto the heater and when it came on fuse blows.
You may never know what the original diagnosis was so dont blame all the experts.
The company has gone off line today but there are as many dodgy engineers out there as independants than eac engineers.
May 22, 2006 at 4:27 pm #176769bendaireboy
whoop’s sorry expertcat it was not my intention to upset ‘x’ expert engineer’s[or anyone else for that matter ,not my style] only to say i have the unenviable task to go in after some one else ,it is a hard enough job with out some one slagging other’s off 😳 nige p.s. thank’s for advice
May 25, 2006 at 5:28 pm #176770expertcat
Participantjust a bit bitter.
suppose still proud of being an expert engineer loyal till that last bitter end.
I look at myself as being the best of the best used to be always in the top 10 of my region with first time calls completed.
its a bit scary being your own boss but saying that done 16 jobs this week on a 3 day week after taking van back to depot.
May 25, 2006 at 6:04 pm #176771Dales-Electronic
ModeratorRe: samsung sg2028css cutting out
Expert Cat may be able to confirm this but during my training course last week it came up that Samsung had been having problems with the thermal fuse. Original is wrapped up with a piece of foam sheet, engineers were fitting the replacement without wrapping this foam around causing premature failure of fuse. The original fuse was set at 73C but I note that the ones supplied to us this week are at 77C.
June 1, 2006 at 9:10 am #176772bendaireboy
has anyone by any chance got a service manual for this little fella?
June 1, 2006 at 7:17 pm #176773expertcat
ParticipantThe fuses still blow on the ones wrapped with foam.
All of the ones I have changed have come back my advice would be to not fit the thermal fuse near the heater.
I have moved the thermal fuse upto the area where the connectors are and they have not come back.
Would also advise replacing the sensor as these have been a problem.
