Samsung side-by-side, freezer ok but fridge temp too high
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung side-by-side, freezer ok but fridge temp too high
  • #58598
    Ametyst
    Hello everyone!
    Hope you guys can help. My Samsung side-by-side RSH1DTMH (purchased March 2008) is … well, broken I think.
    I’ve had a look at other topics and I find similarities but nothing lthat matches my fault a hundred per cent.
    The freezer is fine, it keeps the temp at -16 degrees but the fridge temperature is way too high. I cannot seem to get it below 12 degrees! Now there was some icing around the deodoriser slits so I turned on the ‘vacation’ option to turn of the fridge section and left the door open all day. I believe the ice did thaw but when I turned it back on it still does not go below 12 degrees.
    The fridge/freezer does not make any noises. Does anyone have any idea what else I can do before I have to call out an engineer?
    Many thanks!!!!!
    #335037
    Re: Samsung side-by-side, freezer ok but fridge temp too hig
    if you havent had the aditional fuse board fitted then call samsung who will repair it F.O.C.
    Bryan
