My Samsung speed oven FQ159st’ door basically exploded on Saturday with glass all over the kitchen. I have found a new door online but I can’t work out how to get the current door off. There is no lock or clip and if I lever the door the hinges do move in the oven housing but the door does not come away. Any suggestions??
Are there “holes” in the hinge, some require pins placing through the holes when the door is then pushed towards the closed position the pins take the tension and the hinges lift off the receivers.
