SAMSUNG SR-20/SR-22 Freezer problem Home › Forums › Public Support Forums › General Enquiries And Questions › SAMSUNG SR-20/SR-22 Freezer problem This topic has 1 reply, 2 voices, and was last updated 13 years, 7 months ago by bbull26. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts August 28, 2012 at 12:06 pm #71173 bbull26Participant Hi, I have a problem with my Samsung SR20 american style fridge/freezer, in the freezer part only the bottom half is freezing but the top half is not. Any ideas what the problem may be and whether its worth fixing/calling out an engineer or should I just replace it since it is over 7 years old. Appreciate any thoughts, Thanks. August 28, 2012 at 8:07 pm #380242 SAMURIParticipant Re: SAMSUNG SR-20/SR-22 Freezer problem This will be worth calling an engineer as it is most likely a defrost fault or the fan motor. You can try turning it off for 48hours with the doors open. If when when you turn it back on it cools down ok after a few hours then it is a defrost fault. If the problem then returns in a few weeks then you will need an engineer to fix the defrost system. Bob Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
