Samsung SR-L3216B defrost sensor and thermal fuse
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Samsung SR-L3216B defrost sensor and thermal fuse
  • #40115
    Simon46
    Can anybody tell me the part numbers for the above. Fridge works then goes off until switched off/on at wall.
    S.
    #264800
    aclarke
    Re: Samsung SR-L3216B defrost sensor and thermal fuse
    DA81-00730A SENSOR
    DA81-00731A FUSE
    #264801
    The fault is more likely to be the defrost heater assembly.
    bryan
    #264802
    Simon46
    Metered it found heater ok. Defrost sensor 25 K fuse OC.
    Many thanks
    S.
    #264803
    Simon46
    My local supplier says these are obsolete? Does any one have them in stock?
    S.
    #264804
    Hi Simon
    Do you have a RS21 thermal fuse ? if so then it is the same rating but a different connector.Cut the old plug off and butt connect the new fuse to it.
    Bryan
