Samsung SR-L3216B Fridge not working, freezer OK
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung SR-L3216B Fridge not working, freezer OK
  • #30378
    drkaraokephd
    I come here in the hope that the folks on this site have more intelligence than Samsung!! (won’t be difficult!!)
    I have this fridge freezer and the fridge has stopped working. On removing the front cover to access the pcb, I find that the green led on the board is flashing twice quickly then pausing then flashing etc. Does anyone have any ideas what fault condition this represents (as Samsung don’t seem to know, or won’t say?)
    Thank you all in advance.
    #226979
    Re: Samsung SR-L3216B Fridge not working, freezer OK
    The fault is within the defrost system,The appliance hasnt been able to complete a full defrost within 80 min’s.
    The freezer will fail shortly if not repaired.
    Bryan
    #226980
    drkaraokephd
    Thanks for your reply r600a (Bryan)
    What does the repair entail, if it’s an electronic repair, I don’t mind doing it as I’m an electronic engineer by trade!..However, if it’s anything to do with the gas side….forget it!! lol
    One further question (if you don’t mind) Why will the freezer side fail??
    Thanks for your time & patience
    Nigel
    #226981
    drkaraokephd
    Ok saga continues…reset unit left it 90 mins…freezer came back on but no fridge, can hear fan going but no cold air coming into fridge.
    The fridge sensor has 4 wires, 2 grey reading approk 1k fixed and 2 white, variable with temp but approx 10.8k at room temp….anyone know if these readings are correct
    #226982
    It’s either the thermal overload or defrost heater.both dont need regas.
    Bryan
    #226983
    drkaraokephd
    Thanx Bryan, I’ll take it to bits tomorrow and try and find the faulty component…..you’re a STAR 😆
    #226984
    drkaraokephd
    Major thanx, the fridge is now working 😀
    Accurate fault diagnosis as well !!!!
    Star all round
