samsung sr-L36 fridge warm
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum samsung sr-L36 fridge warm
  • #20683
    crav79
    hi, i have a samung sr-L36 fridge freezer. the freezer is working fine but the fridge is warm about 19 degrees c. I have tried defrosting it and when i switched it back on it did seem to be cooler but within a day it is warm again.Everything else seems to be o.k ie the light and fan, just wondered if anyone has any other ideas?
    #187994
    Dales-Electronic
    Re: samsung sr-L36 fridge warm
    Before we go any further, does you machine have a digital readout or only led’s on the top control panel. Secondly have you got any of the led’s flashing or is there a fault code in the display area (if fitted)?
    #187995
    crav79
    Dales-Electronic wrote:Before we go any further, does you machine have a digital readout or only led’s on the top control panel. Secondly have you got any of the led’s flashing or is there a fault code in the display area (if fitted)?
    it has just the led’s and none of the led’s are flashing thanks for replying
    #187996
    expertcat
    could be compressor going into overheat protection.
    unless you call an engineer out it could be anything give repairs@ ago
    #187997
    crav79
    i have once again defrosted the fridge freezer and the fridge is now operating between 4 and 9 degrees but the the freezer is now not freezing, it is just cool aprox same temp as fridge. any ideas please?
