Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung SR-L3616B cool n cool
- This topic has 9 replies, 3 voices, and was last updated 10 years, 8 months ago by
Reubenw.
July 21, 2015 at 6:28 pm #85605
Reubenw
ParticipantHello fridge gurus. Hopefully this is an easy question to answer, it has me stumped but I’ve not looked into a fridge before (other than for beer obviously!)
I have what seems to be a common problem for the SR-L3616 ‘cool n cool’fridge freezer. It cools down to -25c (checked with thermometer), cuts out and restarts when Mains switch is reset. I have opened it up and checked the defrost heater cable has continuity(as suggested somewhere online), the two yellow thermostats , (one in the air flow, one on the evap) have full range. There is a small device attached to evap beside thermostats which I don’t recognise which has zero resistance both when at warm air temp and at max cold. Is it some kind of switch? Is it the problem? Is it something else.
Please help, all the dog food is defrosting and my dog will burst of it had to eat it all at once.
July 21, 2015 at 6:33 pm #429046SAMURI
ParticipantRe: Samsung SR-L3616B cool n cool
The part you mention is a thermal fuse and should have continuity.
This is the fault you need to replace it.
Bob
July 22, 2015 at 12:09 pm #429047Reubenw
Thanks for reply Bob. I’ve slightly misled you unintentionally. The fuse is OK, it has zero ohms reading. The heater about 8.4 k ohms. Any other suggestions, or bits to measure! Would be appreciated since the kids are now moaning their lollies have all been thrown out! Ta!
July 22, 2015 at 7:46 pm #429048SAMURI
It will be the thermal fuse faulty and needs replacing. The two sensors and heater sounds ok with the readings you have given.
Bob
July 23, 2015 at 9:07 am #429049Reubenw
OK will change, and let you know how it goes! Thank-you!
July 30, 2015 at 8:45 am #429050Reubenw
Well the thermal fuse arrived and I fitted and tested. Seemed to work during day and cycle between -22 and -16, but affected by people opening fridge regularly i suspect. overnight it went down to -28 again and tripped out.
Any other suggestions?
July 30, 2015 at 9:25 am #429051admin
KeymasterRe: Samsung SR-L3616B cool n cool
Defrost heater
If you need one i have in stockAugust 1, 2015 at 5:21 pm #429052Reubenw
r600a wrote:Hi
Defrost heater
If you need one i have in stockBryan service@ffrservices.co.uk
Thanks for suggestion r600a. What should the resistance reading be for a new one? The existing is about 8.4k ohms
Thanks.August 1, 2015 at 5:21 pm #429053Reubenw
r600a wrote:Hi
Defrost heater
Thanks.August 2, 2015 at 2:26 pm #429054admin
I have no idea as its on a shelf in the stock room
Bryan
