Samsung SR-L3626B fault code RD?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung SR-L3626B fault code RD?
  • #55161
    jocarl11
    Hi, Just been given a Samsung SR-L3626B fridge freezer and when i powered it on everything was fine for about 5 seconds then it cut out and the digital display just flashes RD! Before i was given it i was aware the refrigerator was stuck at 1-2c because of a possible faulty thermostat? But doesn’t sound like that’s anything to do with this fault.
    Does anyone know what the RD means?
    Regards Carl.
    #322128
    BobHope
    Re: Samsung SR-L3626B fault code RD?
    Hi Carl,
    you have a problem with the damper/baffle or one of its componants.
    Bob.
    #322129
    jocarl11
    Thanks for the quick reply Bob, Please can you explain what the damper/baffle is? I’m wanting to do the repair myself but don’t know where to start or where to get the parts for my appliance?
    Thanks Carl.
    #322130
    jocarl11
    Ok I have done a little searching and as far as i can tell the damper blows cold air from the freezer to the fridge so the damper must be behind my freezer compartment? Is there any checks i should do to know what may have actually packed up?
    Thanks in advance Carl.
    #322131
    jocarl11
    I have taken of the plastic backing from the freezer and saw the damper rotating when i turned the fridge freezer on but after 4 seconds i hear a click from the top of the fridge and everything shuts down with the rd error? The damper and motor must be fine for it to spin so perhaps a sensor?
    Also the was no ice present at all.
    #322132
    jocarl11
    Can anybody help with this one? I have ordered a new sensor but have no idea if it’s that or something else 🙁
    #322133
    You will need a new evaperator cover which we can supply.
    e-mail me at samsung@ffrservices.co.uk
    bryan
