Samsung SR-L39
  • #57946
    macuddie
    My fridge/freezer keeps alarming and scrolling between super freeze and normal. Everything else appears to be working as normal apart from the continual scrolling and alarming every 20 to 30 seconds.
    Can anyone advise on whether this is repairable or terminal?
    #332766
    SAMURI
    Re: Samsung SR-L39
    You need to check if the door has droped a bit as it may not be turning off the internal light switch.
    You may find that the internal light is not on or working intermitantly
    If you are unable to adjust the door your self if this is the problem you can try sticking a penny on top of the door so it turns the switch off.
