Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung SR-L3928B Fridge/Freezer switches off then back on
- This topic has 7 replies, 4 voices, and was last updated 12 years, 10 months ago by
DJ59.
June 5, 2013 at 3:58 pm #75729
DJ59
ParticipantMy fridge/freezer (Samsung SR-L3928B) intermittently goes off then comes back on by itself, When this happens I hear bleeping.
When it is off there is no display and no light inside the fridge. When it comes back on the disply shows ‘–‘ and the light comes on in the fridge.
If I press a few buttons, i.e. Freezer, Ref, Eco then the temperature shows or Eco shows. They usually flash but sometimes they are static. When it comes back on it is okay and then could work for a few days before the same thing happens but usually this occurs every day.
I have had the control PCB out to check connections and it looks okay. To me it appears to be the PCB that is causing the problem but I would appreciate any guidance available.
If it needs a new PCB then suggestions as to where and how much would also be helpful.
June 10, 2013 at 6:01 am #395964admin
KeymasterRe: Samsung SR-L3928B Fridge/Freezer switches off then back
HI
Check your defrost heater.
Bryan
June 25, 2013 at 9:07 pm #395965Jim_Bob
ParticipantRe: Samsung SR-L3928B Fridge/Freezer switches off then back
We are having exactly the same problem. It occurred a few months ago but rectified itself after a couple of days just when I was going to call someone out, now it has returned.
How do I tell if it is the defrost heater that is at fault?June 26, 2013 at 8:21 am #395966admin
You meter it.
Bryan
July 1, 2013 at 11:52 am #395967DJ59
I went with the advice and bought a Defrost Heater. Unfortunately, after taking panels off: lower back outside, fridge inner rear, freezer rear and control panel top outside, I could not find where the Defrost Heater is located.
Does anyone have any idea where I can find it?
July 1, 2013 at 7:24 pm #395968TeeMyob
Try loer back inside!
TM
July 3, 2013 at 1:09 pm #395969DJ59
When I said ‘Freezer rear’ I meant the lower back inside. I couldn’t find anything there other than some cables at left and no further access into anything else that may be ‘hidden’.
If the Defrost Heater is definitely on the sinde at the back of the freezer I will have a look again.
July 3, 2013 at 2:21 pm #395970admin
Inside behind the rear panel.
Bryan
