Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung SR-L629EV
- This topic has 5 replies, 5 voices, and was last updated 19 years, 7 months ago by
dek2904.
August 26, 2006 at 11:18 pm #20323
dek2904
ParticipantSamsung SR-L629EV serial no. 602041ATA00028 B
Hello group,
My Samsung fridge freezer is 4 years old and has been giving some problems recently. Freezer was ok, but fridge would only register 9 degrees. Service Engineer from insurance co came out and said thermostat problem, easy repair. We waited 3 weeks for him to come out and fit. When I came home there was bits of fridge all over the kitchen- but no engineer. He’d said the Samsung was a write-off and the freezer was also kaput. I wasn’t best pleased about the service and complained. The ins co offered to buy us a new one (£950) as long as we paid up the insurance (£160). Which is ok.
But our written off freezer continued to work ok. I managed to take off the polystyrene insulation at the back inside the fridge (unit isolated) and found the heat exchanger inside a block of ice. I used a hair dryer and defrosted it. Then I turned the fridge back on and Bingo! Nothing worked! Even the freezer had stopped. But there was a “d” flashing on the display. I tried leaving it to stand for a while, but it didn’t come on. Fiddled about removing various connectors but still ended up with the same old “d”. So left it for 3 days, turned it on to try something else, and it came on ok by itself, with fridge and freezer working. Now its running ok, although I’m sure that the original fault must still exist. I’m just going to keep an eye on that heat exchanger in the back of the fridge.
What I want to know is this: What does “d” represent as a fault code; if one of my thermisters has failed, which is it likely to be and how much do they cost; why did it take so long for my Samsung to decide to work?August 27, 2006 at 10:47 am #186669Washman
ParticipantRe: Samsung SR-L629EV
“d” in display means a fridge defrost sensor faulty .
Mike
August 28, 2006 at 2:39 pm #186670dek2904
ParticipantThanks Mike…
August 21, 2020 at 11:08 am #186671Jeroen
ParticipantI’ll guess you already have a new fridge by now, since it is 14 years later after you posted this,
We encountered the same problem with the flashing d, because we had the fridge defrosted to move it to an other place.
When you press the buttons Quick Freeze and Quick Cool together for approximately 10 seconds it should be working again.
August 21, 2020 at 12:10 pm #186672Gokhk
ParticipantHad a similar incident with our samsung , 7 years old and written off i dont think lots of insurance repair guys know what they are doing to be honest they did various repairs which never lasted more than 1 year , i think its a bad design of defrost system. Ice collects and it doesn’t defrost due to sensor issues believe. They even allegedly reprogrammed pcb and fitted a redesigned part but still same old faults. Scrapping sadly.
January 28, 2021 at 8:33 pm #186673Kotesz
ParticipantHello, i have a similar problem, fridge temp is stay on 9 degrees. The freezer temp is -19 degrees i think this is allright. Please help me what mean this
