Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung SR-S20 Fridge Freezer, Not Constantly Freezing. HELP
- This topic has 3 replies, 3 voices, and was last updated 16 years, 3 months ago by
Lettuce.
December 19, 2009 at 2:45 pm #51078
Lettuce
ParticipantHi all am new to these forums, so hello.
We have a Samsung SR-S20 American Style Fridge Freezer, which has a problem on the freezer side of the unit. Basically the freezer stops freezing. If you press the quick freeze button the freezer would actually freeze but as soon as the temperature starts to rise the freezer doesn’t kick in again, and so food starts to defrost.
We first thought it was the LCD control panel on the front of the unit, as it was sticking and you had trouble changing the temperatures etc. We had an engineer out who change the whole LCD panel, and was no longer stick, but after we freezed the unit again, it would warm up and the freezer wouldn’t kick in. So the engineer came out again this time he first swapped the sensors over from the fridge to the freezer to see if this helped, it didn’t, he then came back the next day and changed the compressor on the freezer side, he went away and the freezer started to freeze, but yet again in the morning everything had deforested. We got the engineer back 1 final time this time he changed the circulating fan, and yet again this didn’t help.
In the end Samsung gave us a whole new unit. They didn’t take our old unit away and it has been sat in our garage for about 12 months now. We now need the space so I am thinking of sticking it on eBay the way it is, some in the industry will probably be able to get it fixed for cheap so will have a bargin, as I think this was around £900 quid when we bought. I would like to try and fix it so I could ask more for it on eBay, does anyone have any suggestion what the problem might be and a possible fix?
December 20, 2009 at 3:27 pm #306847johnsdad
ParticipantRe: Samsung SR-S20 Fridge Freezer, Not Constantly Freezing.
most likely fault is defrost heater
December 21, 2009 at 8:57 pm #306848Lettuce
these cheap and easy to replace?
December 31, 2009 at 11:46 pm #306849bazzey
there is thermo sensor in freezer and refrigerator compartments.
They are wired in series as far as defrost circuit is concern therefore if either of them are blown, the fridge freezer will be locked in defrost cycle and the inside temperature will start to rise.
one is looking for a loop test or a reading of 0.1 Ohms with a multi meter (test the meter test leads resistance because this will need to be deducted from the sensor reading).
move onto defrost heater and identify which of the two is faulty if thermo sensors are Ok.
