Hello, I need a little advice regarding the above named fridge freezer. I have gained a little advice from these forums but how if at all can I remove the plastic plate with the label ‘twin cooling’ on the inside of the fridge compartment, this is where the ice is. I have removed the screws and it has started to move but I didn’t want to pull it any further without speaking to someone with greater experience than myself.
Thanks. Chris
Hi thanks for that, it must be really froze up at the back cos it has a small crack in it now!
Do any of the other pieces have to be removed ie the bits from this plate towards the light?
