samsung sr-s2028 cuw
  • #52465
    agro
    hi guys anyone had this fault the compressor fan does not run and the fridge fan doesnt normally fan at back comes on when the motor runs the fridge working ok already had the mod kit but the freezer only gets down to -10 not the module as i had a spare diagos on pcb comes up with no errors very strange thermal fusses checked will just suddenly stop and then defrosts
    #311891
    chezza
    Re: samsung sr-s2028 cuw
    Any chance of having that in english ?
    #311892
    agro
    please only sensible replies as i take technical queries serious
    #311893
    Sorry Agro, it doesn’t read very well.
    “Hi guys,
    Anyone had this fault? The compressor fan does not run and the fridge fan doesn’t. Normally, fan at back comes on when the motor runs. The fridge is working ok. Already had the mod kit but the freezer only gets down to -10. Not the module, as i had a spare. Diagosis on pcb comes up with no errors – very strange. Thermal fuses checked. It will just suddenly stop and then defrosts.”
    Hope that will help,
    defrost heater..simple
    There is another point though… who fitted a mod board to this model ??? It shouldnt have one.
    bryan
    #311895
    chezza
    agro wrote: i take technical queries serious
    And so do we all …. which is why when I look for help , I try to give as much information and be as clear as possible . Surely it is easier to help those helping you than using playground slang and no punctuation ?
    #311896
    funkyboogy
    must admit i agrre with chezza on this… orig post very hard to undertand?
    what do you mean with mod kit ??? …
    agree with 600a defrost heater , also check drain hole heater in fridge compartment , famous for the little wires that go down drain hole corroding..on this older model
    ally
