Samsung SR-S2028CSS fridge freezer problem, plz help
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung SR-S2028CSS fridge freezer problem, plz help
  • #50417
    sparks1970
    Hi, my appliance keeps cutting out and does not keep cool in either fridge or freezer, if I switch it off and back on again it will work for so many hours and will cut out again, is it something that can be repaired and if so would it be worth repairing ? ❓ regards
    #304768
    Re: Samsung SR-S2028CSS fridge freezer problem, plz help
    hi
    the problem will be either the defrost heater or thermal fuse.
    bryan
    #304769
    sparks1970
    Hi Brian, thank you for your reply, how do check these to identify the faulty part and where are these located, sorry Im a noob. Would it be expensive to replace, regards.
    #304770
    sparks1970
    Can anyone advise to my last post as my food is defrosting , regards 😯
    #304771
    Kez
    Quite a specialised area these – if you provide the first part of your post-code, I’m sure someone will recommend a reputable engineer 🙂
    #304772
    sparks1970
    Hi, can you recommend someone, regards.
    #304773
    spimps
    Hereyou are.
