Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung SR-S2028CVW
- This topic has 10 replies, 3 voices, and was last updated 18 years ago by
cuna44.
April 13, 2008 at 12:23 pm #35979
cuna44
ParticipantI have a Samsung SR-S2028CVW American style fridge/freezer. My problem is the Ice compartment is not getting any water. There is water getting to the water dispenser on the front of the freezer, but there is nothing filling the ice tray.
If there is a blockage I can not see how I get to the pipe to see where it is?
April 13, 2008 at 12:27 pm #248958admin
KeymasterRe: Samsung SR-S2028CVW
Have you tried resetting the ice maker ?
Hold the small black button in for approx 10 seconds on the botton of the square box on the front of the ice maker.
Bryan
April 13, 2008 at 1:46 pm #248959cuna44
ParticipantRe: Samsung SR-S2028CVW
Yep done that quite a few times with no results. Even defosted the freezer incase the pipe had frozen up. Still no water
April 13, 2008 at 1:48 pm #248960kwatt
KeymasterInlet blockage or inlet valve failure.
Ours gets blocked due to the gunk in the water every few years and I have to change the valve. 😕
April 13, 2008 at 1:50 pm #248961admin
It’ll either be the water valve or the Ice maker itself.First test would be the water valve unless the engineer has an ice maker then that would be the easier option.
Bryan
April 13, 2008 at 1:51 pm #248962kwatt
KeymasterCan the delivery tube/hose freeze on them Bryan? Mine does on occasion and I have manually clear it on the Maytag, not often it has to be said that I have to do it, but it does happen.
April 13, 2008 at 1:53 pm #248963admin
Hi K
Frozen fill pipe not an issue on these unlike several others,even when the water valve drips due to non sealing it doesnt freeze up.
Bryan
April 13, 2008 at 1:54 pm #248964kwatt
KeymasterJust a thought. 😉
April 13, 2008 at 1:58 pm #248965admin
Now if it was a certain other makes then yes they do.
bryan
April 13, 2008 at 2:33 pm #248966cuna44
Participantkwatt wrote:Inlet blockage or inlet valve failure.
Where do I locate the inlet valve to the ice maker. And is it easy to replace if it is the problem?
Thanx
April 13, 2008 at 3:34 pm #248967admin
The water valve is at the rear of the appliance behind the bottom panel,unles you know how to use a meter then you wont be able to test it…POWER OFF before removing panels.
Bryan
