Another Samsung side by side…problem is the fridge evap ices up as though it doesn’t actually do a defrost cycle. The fridge defrost heater and fuse is fine, I’ve already replaced the evap cover as the ice was initially catching the fan so thats been modded already. The freezer incidentally seems fine…
Fridge section bottom left ” ice maker has failed me than 3 times,(you could try to solder the sensor wires if broken)
Fridge bottom right is fridge defrost sensor failure.
Freezer bottom is the fan is not sending a signal back to the board. (normally bad connection/corrosion on the board connector)
If you need the parts give me a call.
