the fridge is cooling down and the freezer ok but the condenser fan will not run. getting no voltage at the connection point ,12 volt dc fan has a circut , can any one help with this thanks in advance phil
Hi Phil
Is the unit in a cold environment? If so this may help.
Under the top left side hinge cover you will find an ambient sensor, this stops/delays the condensor fan if the ambient temp is cold usually below 13 degrees
