We had a recent problem with the common noisy fan issue which was down to a build up of ice in the top back of fridge, obstructing the fan. We managed to remove back cover and use a hair-dryer to remove ice and clear drain hole. We then reassembled the fridge. BTW, freezer was still working fine at this stage.
Now, the fridge and freezer does not appear to be maintaining low temperatures. After initial power on, the FF seems fine and ice maker works ok. But after some time, the FF seems to go quiet and appears to defrost – showing some residual water under unit?
Any suggestions most welcome. Is there a self test we can perform to check the FF components?
Cheers
Terry
Model Number S24AHESWQN /EST
