Samsung SRL3616B – works at the start but won’t after that
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung SRL3616B – works at the start but won’t after that
  • #36405
    hospice58
    I have a Samsung SRL3116b frdige freezer.
    The fridge works fine when switched on initially and after a while it goes to standby.
    However, despite the temperature dropping it never cools again unless one turns it off and on again.
    Can you help me:
    – is this definately the thermostat ?
    – or the thermo fuse assembly
    – do you know where any good manuals are for diagnosing
    – how can I contact samsung to get help
    – where can I get the spare parts ?
    I have searched the web many times with no joy
    Any help much appreciated !
    #250880
    Re: Samsung SRL3616B – works at the start but won’t after th
    The problem will most likely be within the defrost area,either the defrost sensor or the defrost heater.
    I can supply the spares if required.
    Bryan
    #250881
    Hairlocks
    I have the same problem, did you find out the reason?
    Mine stops working altogether and pressing the power or ref.temp buttons does nothing. I have to switch of at the wall and wait a few minutes!
