My fridge/freezer does not stay on the required tempreture. It scrolls from -17 to-25 with the alarm going (or a noise at least)I have had an engineer look at it and he can find nothing wrong, This freezer can go days with being alright and then plays up. Only the freezer side is affected. Please help!!!!
On the top of the fridge door you will see a line where the light switch is activated. Get a 1p and super glue it onto the top of your door in the centre of this line. Common problem is that the door drops due to insufficient strength in the framework to support the door and the weight.
