samsung srl3916bss problem
  • #41016
    shonight
    i have got one which is fine until you turn it off. when turned back on i got some kind of error code.
    the appl has on the facia from left to right an on/off button 5 led’s and a temp button
    the error code was the 3rd led flashing and nothing else worked, if left for about 24hrs the appl would start to work againg.
    any ideas???
    thanx
    #268360
    alro
    Re: samsung srl3916bss problem
    remove rear in freezer 4 screws ,remove 2screws fan unplug connectors plus the 8way back left side near motor flap remove cover to expose the evap,you will find defrost heater on evap is o/c you properly have to change evap with heater as it may not come as a part + regas
    alro
