Samsung srs 2028cvw
  • #34014
    fastway
    Hello folks, I hope someone out there can give me a little advice. I have a problem with my side by side similar to others I’ve read about on this forum. The fridge and freezer go into permanent defrost mode after about 11 or 12 hours of normal operation and the figure I have set on the freezer side is flashing. I turn it off and on and hey presto the true temperature shows and it works fine for another 12 hours. I’ve tried the diagnostics as described within this site and it shows no error. Any ideas please, even if I could just explain to the engineer what I have learnt if I have to get one in, it would help.
    Cheers
    chas
    #240874
    helo_75
    the defrost heaters probably faulty
    can only buy as part of the evaporator, but it can be prized off
    comes complete with defrost sensor and thermal cut out, advisable to change all 3 components to ensure affective repair
    #240875
    fastway
    Re: Samsung srs 2028cvw
    Thanks for the reply Helo_75, Just to clarify if I may: This is the Freezer side? and I need to buy the evaporator and remove from it the defrost heater, defrot sensor and the thermal cut out?
    And where do I order?
    Thanks again
    Chas
    #240876
    expertcat
    very unusal for freezer defrost heater to fail.
    Never seen one fail in 9 years its always the fridge side that plays up.
    Most likely sensor and thermal fuse.
    #240877
    fastway
    Thanks for that expertcat. would not the flashing number on the freezer side indicate a problem there?
    cheers
    chas
    #240878
    helo_75
    the only way you’ll ever be sure of a fault is to get a meter out and test
    reasoning for considering the defrost heater is faulty?
    the sensor has switched the machine to defrost, and because the heater is faulty, it wont defrost, will it?
    therefore, it switches off, untill the point where it either defrosts naturally, which could take days,or you manually restart it by unplugging/plugging it back in
    either way, the fault lies in the fridge, not the freezer, ive NEVER done any work on the freezser side personally
    and i fix a LOT of them
    #240879
    buffer
    Thanks for that valuable information helo_75. I tested the defrost heater and the drain heater of the fridge side using a simple 9v circuit test and both, after lots of attempts show as open circuits. The heaters on the freezer side however show a closed circuit and a full flow of juice. Heaven knows about resistance. Would I be right in concluding that the fridge heaters are dead?
    Cheers
    chas
    #240880
    helo_75
    what you really need to do is disconnect the 2 heaters
    if you test them together, and one is faulty (open circuit) it will show, regardless of which one
    youll probably find the defrost heater is the culprit, as per my original post
    order the evaporator, and change the heater , sensor, and thermal fuse , because theye updated the sensor, and its best to renew everything
    #240881
    colinallcars
    My fridge/freezer (Samsung SR-S2028CVW) has the widely reported fault of failing to cool on both sides, temporarily fixed by swithching off and on. I removed the internal rear panels on both sides expecting to find a build up of ice but there is none. This suggests to me that the defrost heaters are working and that a sensor is faulty – do the experts agree? If so, what’s the most likely culprit?
    #240882
    the problem could either be the defrost sensor or heater or overload,does the appliace switch off for any legth of toime?
    Bryan
    #240883
    colinallcars
    Thanks for the quick reply – much appreciated.
    When it’s in the fail mode it doesn’t restart cooling by itself, I have to switch it off then on again. Lights, panel display etc. still work – just no cooling. No errors show when I run the diagnostic routine from the panel.
