SAMSUNG SRS20 S/SFRIDGE FREEZER
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SAMSUNG SRS20 S/SFRIDGE FREEZER
  • #49903
    mbdas
    HI 🙂
    Called to this fridge freezer this morning the compliant was freezer defrosted . I put it in sevice mode and no faults were indicated and also put it in forced operation and seemed ok ❓ took both evaporator covers off and checked elements toc’s & ntc everthing checks out ok .after 30mins doing all this I put it back together and its fired into life ( not literary 😆 ) when I first walked into the kitchen I did notice it was cold 12oC so Im now thinking its the ambient temp and its switching off in the night. On the back of her instruction book there is alist of temp classes SN N ST T so I checked the Class on the appliance and its T tropical minimum 18oC ( has someone told the Koreans the UK is in the tropics or something 😆 ) has anyone had this problem before and can it be changed to class SN and what parts are needed 😕
    Thanks Mark 😀
    #302704
    funkyboogy
    Re: SAMSUNG SRS20 S/SFRIDGE FREEZER
    we had a few of these that run ok untill they enter defo mode..
    then they switch off.. if customer switch of at socket and then back on f/f will run ok untill defo.. if this is what this is doing it will be the drain hole heater in fridge , the 2 wires that go down drain hole will be perished o/c ..
    its a bit of a funny one to diagnose but i would check this part if you havent done so already.. drain hole heater is independant of evap heater
    ally
    #302705
    mbdas
    thanks ally 🙂
    I did check the heater and it was ok but thinking about it I dont think I disconnected it from the evap heater so I will pop back and check it again 🙂 mark
    #302706
    mbdas
    hi Ive only just been back to this fridge and your spot on 🙂 but when I removed the heater it has made a real mess of the cabinet under neath it Its lucky its not set on fire ❗ have you seen this happen before and do you know Y ❓ I don’t want to fit another for it to go up :rolls:
    Any advice would be great 🙂
    Mark 🙂
    #302707
    funkyboogy
    we have seen lots with this type of drain heater failure and the mess it leaves , i have always just replaced and had no probs …
    think its build up of water and breakdown of heater wire that causes mess…
    ally..
