Re: samsung srs2026
Hello,
Never heard of that one. And I see on average 10 samsung american a week.
Common fault on the older twin cooling was/is the Fridge Evap Heater, thermal fuse, Defrost sensor or usual moisture ingress into Evap cover.
Problem was if the Heater or Thermal fuse in the fridge failed, the module was programmed to stay off until the fridge evap reaches room temperature. Result is freezer defrosts, unless customer de-powers – re-powers appliance.
On the later RS21 series. Should the defrost not be attained on the evaporators within “I Think” 45-50 mins. Then the module swithes back to rerigeration mode.End an error is stored in the module as a horizontal line in the centre of the relevant 8
Hope this helps?
TM
