Samsung SRS2028 freezer not cold enough
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung SRS2028 freezer not cold enough
  • #82153
    Washdisher
    Fridge at 3degC, freezer temp display flashing and although freezing, is not getting cold enough.
    Comp not getting hot and was not running when I arrived.
    Continuity across freezer heaters, temp sensor and TOC.
    Both evap fans and cond fan all running ok.
    No build up of ice anywhere.
    Rather choked up evap coils which I dusted out.
    Bit baffled really. Do these have a diverter valve to channel refrigerant between fridge and freezer evaporators, and if so could this be the problem?
    Dez
    #418906
    SAMURI
    Re: Samsung SRS2028 freezer not cold enough
    If the condenser fan motor was working and the compressor was not running it may have a faulty compressor relay as the compressor should be running if the fan is working.
    No diverter valve fitted on this model
    Bob
    #418907
    Washdisher
    Hi Bob,
    The compressor was not running on arrival, ie it had got down to the ‘correct’ temp. Comp and fans all kicked in after I’d metered defrost comps and plugged it back in. Sorry, I should have been clearer.
    Dez
    #418908
    Then it’ll be defrost circuit. If you’ve checked them.. Check again
    Bryan
    #418909
    Washdisher
    Hi Bryan,
    Pretty confident re all defrost components except for sensor as I don’t know what resistance values this should return for any given temp. All I can say is that it was about 12K ohms at about 20degC. I’ll try swapping it anyway, and see what happens.
    Thanks for your reply.
    Dez
    #418910
    Did you disconnect the heaters before you tested them ?
    Bryan
    #418911
    Washdisher
    Hi Bryan,
    Indeed I did
    Dez
    #418912
    Washdisher
    Spoke to customer this am. Freezer temp is now down to -20degC. This is since I restarted it about 48hrs ago. I’ve come across the usual freezing up faults on the likes of RS21 and RSH1, and also observed a Samsumg refusing to operate after failing to defrost just once after being switched on – this was due to an OC TOC. This problem does however seem different again. Is there a kind person who could mail me technical info on these machines so that I can get a better idea of how they work?
    Dez
    #418913
    E-mail me
    bryan@ffrservices.co.uk and i’ll send you the test sheet
    Bryan
    #418914
    Washdisher
    Turned out to be the fridge defrost heater.
