samsung srs2028css ice problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries samsung srs2028css ice problem
  • #31301
    wray
    one of my engineers is having some problems with this model and wonder if anyone has come across this before.
    the fridge fan will become iced up after about a day and this will cause the fan motor to become noisy and then stop. the appliance is defrosting fine and there is no ice anywhere else in the fridge compartment.
    so far my engineer has changed the eveperator cover and fan motor as he thought this was the problem but this has made no difference. he has checked all over the appliance to see if there is warm air getting in but has found nothing, he has also metered out all of the sensors and they check ok.
    this is a fault that i have never come across before but these samsung appliances never cease to amaze me.
    any help would be appreciated.
    regards steve
    #230596
    robbo1973
    Re: samsung srs2028css ice problem
    there is a modified evap cover available which must be fit also a modified sensor(black probe) which needs changing other than that heater or therm fuse o/c.
    cheers chris
