Samsung SRS2028CVW
  • #49084
    johnnyj
    I was at a Samsung SRS2028CVW today the fault was not cooling in the freezer, when i removed the evaporator cover the evaporator was perfect even frost over it, however the evaporator fan was not running i tested it and it seemd to test okay, i checked for a supply to the plug but picked up nothing, i assume it must be the pcb, i’m not sure if the fan should run when the compressor kicks in can any body help, thanks jj
    #298712
    robbo1973
    Re: Samsung SRS2028CVW
    the fan runs when the door is closed so if you tested it with the door switch open it would have no supply.
    #298713
    johnnyj
    I taped the door sw in to test for a supply but didnt pick up anything,
