Hi my Samsung srs616dhss side by side fridge/freezer is not staying cold.
It reaches set temperature but then hours later the freezer side on the control panel will flash at set temperature.
Once turned on and off at the wall the correct temperature shows ( warmed up in the fridge and freezer) and starts to cool again.
It also happens when the fridge seems to be working fine but once switched on and off will reset the temperature again.(warm both sides).
Thinking this could possible be a defrost problem?
If anyone could shed some light that would be great.
