Samsung tumble dryer DV90K6000CW EU
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung tumble dryer DV90K6000CW EU
  • #102783
    dunston
    The dryer will run for about 5 minutes then it switches off. The display goes blank. Cannot select a program and won’t switch on.
    Then when its unplugged then plugged in it will switch on and work for 5 minutes then the display goes blank again.
    I’ve tried a different socket – same fault.
    Could be the moulded plug? but its strange that it will come on after being unplugged and plugged in.
    Anyone had this fault?
    #490450
    sounds like a board power supply fault
    you need to be certain you check live and Neutral is getting to the board after failure
