samsung washer
  • #10621
    cornflakes
    model Q1435VGW/XEU
    called by client in a panic,she had decided to wash the throwovers off the lounge furniture. estimate around 20kg of wetfabric inside drum!
    so machine struggles to complete cycle and kicks in error code 8E
    visted last night
    symptoms on spin cycle for test purposes
    machine starts cycle
    motor osolates forward/reverse directions for 10 secs
    error code kicks in 8E
    have removed motor, no signs of burnout
    client says this machine cost them over £600…is it fair to say samsung make good cameras!
    any advice please..I suspect the mod has shot it, due to high current draw
    many thanks
    Graham
    Leicestrshire
    #141153
    Washman
    Re: samsung washer
    Hi Graham
    OVER CURRENT ERROR – Display shows 8E .
    – IPM fault signal (that is caused by the overload of MICOM INT0 during motor action) is sensed.
    IPM : Integrated power module. , IPM controls motor.
    – If the fault signal (low signal) happens to be sensed even one time during cleansing/rinsing stage,
    the motor stops immediately.- During Cleansing or Rinsing
    When the overload is sensed, the motor stops immediately and then proceeds to the next water-flow action.
    If the stopping of the motor working is happens in one direction ten times,
    “8E” Error is displayed.
    When the overload is sensed, the motor stops to work at once and then feeds back to the initial stage unbalance sensing.
    When it happens at more than 800rpm, the process is stopped -Power S/W Off can clear the overload error.
    Is this any help
    Mike
    #141154
    cornflakes
    thanks mike
    top details
    so are we saying we can reset fault readout, by just switching off on/off. if so at which point do you activate sw.
    bearing in mind the motor runs foward/reverse for 10secs, before 8E flashes up.
    graham
    #141155
    Washman
    Re: samsung washer
    Hi Graham
    TEST MODE
    Hold down Rinse and spin buttons and press power sw
    Then press start button
    Test sequence will begin 3 times
    Pre Wash valve on 1 sec off 1 sec
    Cold valve on 1 sec off 1 sec
    Shower valve on 1 sec off 1 sec
    Hot valve on 1 sec off 1 sec
    Drain pump on 1 sec off 1 sec
    DDD pump on 1 sec off 1 sec
    Motor left on 1 sec off 1 sec
    Motor right on 1 sec off 1 sec
    Heater relay on 1 sec off 1 sec
    Thermister test
    All lamps light display shows T1 after 30 sec
    Press rinse and display shows t2 after 30 sec
    Press start button and display shows temp of wash tub .
    Mike
    #141156
    cornflakes
    Re: samsung washer
    mike
    re-visited client, test proceedure runs part way through and than pops up with E8..
    checked clients handbook machine has 5 year parts warrenty..calling the camera people. labour only cost
    many thanks.
    goodthing about the job was the fact it was only 4 doors away from mine.
    Graham
