trying to dry clothes with a Samsung wd0804w8e. stops after about 10 mins with code HE2 , I have checked drain hose and water feed and filter , turned it off at the socket as suggested by Samsung but it still fault y, anybody any ideas what the cause is and approx cost to repair please.
Probably was the dryer`s overload thermostat button clicked out and that was all. They often do that apparently either due to a blockage – common, the fan motor failing – pretty rare -, or simply just trying to dry to much as one single load – more common than you would think.
