Samsung washer dryer WD80J5A10AX – HC error but ongoing fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung washer dryer WD80J5A10AX – HC error but ongoing fault
Viewing 1 post (of 1 total)
  • #102295
    asp11
    Hiya, think I need your help….
    Samsung washer dryer WD80J5A10AX – HC code, did find the connector going to the fan motor off and then tested ok for 20mins and left….. but customer says it’s failed again…. runs well for half the program then just stops and it’s cold inside (fan motor, heater and TOCs ok) the duct goes into a large hose at the bottom so that can’t be blocked. She says it always gets about half way then stops – any ideas please?
