My Samsung eco bubble washer dryer (WD80TA046BX/EU) is having an issue around 15-30 minutes into a drying cycle.
The washer dryer starts to make a juddering noise and an error 5C is displayed.
I have manually drained the washer, checked the filter, removed the pump at the bottom right and cleaned/checked the propeller spins, and I have checked the drain hose is not linked and is not blocked. But I am still having this issue.
The washer dryer washes just fine with no issues so it doesn’t seem to be a drainage issue as per the 5C error code.
This issue only occurs during the drying function.
What could this be?
Many thanks.
