Samsung Washer Model Q1433 – Error code E8
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung Washer Model Q1433 – Error code E8
  • #22269
    whitevanman
    Got a machine with this error code (E8)
    Start Mc on spin pump starts, then the drum clockwise Judders like the second hand on a clock with the battery failing then stops with musical tune showing fault code.
    Samsung tech info displays
    11. OVER CURRENT ERROR – Display shows 8E .
    – IPM fault signal (that is caused by the overload of MICOM INT0 during motor action) is sensed.
    IPM : Integrated power module. , IPM controls motor.
    – If the fault signal (low signal) happens to be sensed even one time during cleansing/rinsing stage,
    the motor stops immediately. However, during dehydrating stage the signal is to be sensed
    when the number of signal is more than 6 for 500ms.
    – During Cleansing or Rinsing
    When the overload is sensed, the motor stops immediately and then proceeds to the next water-flow action.
    If the stopping of the motor working is happens in one direction ten times,
    “8E” Error is displayed.
    – During dehydrating
    When the overload is sensed, the motor stops to work at once and then feeds back to the initial stage of the dehydration unbalance sensing.
    When the feed back is continuously happened 2 times, “8E” Error is displayed During the dehydrating unbalance sensing, No error happens by overload sensing.When it happens at more than 800rpm, the process is stopped compulsorily.
    -Power S/W Off can clear the overload error.
    Q is it the motor or on off a number of Pcbs ?
    Help must appreciated
    Regards
    Wvm
    #194257
    Re: Samsung Washer Model Q1433 – Error code E8
    Fancy way of saying powerboard fault………
    whitevanman
    Penguin45 wrote:Fancy way of saying powerboard fault………
    your not a Nuclear Engineer expert (korean that is) You remind me of MJK8 :rotfl: thanks for the hint though 😀
    Wayne
    #194259
    Pigpen4
    I’ve got a machine with the exact same problem.
    Did you manage to find a part number for the powerboard or obtain a replacement, or was it £_stupid_amount ?
    Thanks,
    Pigpen.
