Samsung Washine Machine Blown PCB AGAIN
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Samsung Washine Machine Blown PCB AGAIN
  • #100703
    JohnHoughton
    I’ve to a Samsung ecobubble WW12H8420EX 12 Kg 1400 Spin Washing machine purchased 2016. The fuse on the PCB blew the other day and i’ve just replaced with a new one (DC9201630A) machine has done 5 washes and now the fuse on the PCB has blown again is this bad luck or is something else causing this. The mains plug and socket are fine and I’m using a 13amp fuse.
    #481818
    provided you are replacing it with the correct fuse then something else it going on
    Inverappin
    Normally a fault with one of the pumps that takes out the board. Good idea to replace both.
