samsung washing machine
  • #37287
    Minge
    Can someone please advise me what T3 on a samsung J1253 means, customer has advised displaying this message and it “just isnt working”!!
    Thank you 🙂
    #254252
    timdowning
    Re: samsung washing machine
    Probably E3.
    3. OVER-FLOW ERROR
    – Display shows ‘ E3’ .
    – Over-Flow error occurs when the water level is in abnormal operation. It can be cleared by turning POWER S/W OFF.
    Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24
    KHz is detected.
    Pressure issue. Check pressure tube isn’t split. Reservoir blocked?
    #254253
    robbo1973
    pressure switch pipe gets damaged at the top where it meets the p/switch by the balance weight very common.
    cheers chris
    #254254
    Minge wrote:Can someone please advise me what T3 on a samsung J1253 means, customer has advised displaying this message and it “just isnt working”!!
    Thank you 🙂
    maybe “tE” which is tacho related???…
    #254255
    dna
    Te is actually ntc open circuit.
    #254256
    gegsy
    3E tacho 😀
