Samsung washing machine 3e fault code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Samsung washing machine 3e fault code
  • #90658
    1totalshambles
    Model wf1124xac/xeu.
    Hi.This Samung machine is fitted with a belt and an induction motor and is less than 3 years old.
    Problem is 3e code crops up very inconsistantly irrespective of load sizes. I`ve checked the cable to the 3 pin motor plug and all looks ok. 3e is motor tacho but that messures ok. *At the top of the tank at the front is a 6 wired sensor, other than sense (!) what does this sense? Is this a Hall sensor? When the machine goes wrong, though I`ve never actually seen it happen, the drum appears to rock left to right right to left about an inch but will not turn the drum. *This sensor is Partmaster part 3648430pm if you want to have a look at it? Any ideas please.
    #445505
    1totalshambles
    Re: Samsung washing machine 3e fault code
    Read around post purchase reviews on this contraption, appears to be either the motor but much more common is the repeating failure of the module….wonderful! This model seems to get a hammering on owners reviews. Think I`ll get out of the repair on this one can see myself losing my shirt in 6 months time, what as long as that!.
