Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Samsung Washing Machine No Power?
- This topic has 2 replies, 2 voices, and was last updated 7 years, 2 months ago by
mickmedway.
January 18, 2019 at 1:22 pm #95334
mickmedway
Participanthi,
I have a cx that has a Samsung washer can’t remember the model, it just had no display or functions power going into the machine, we brought it back to our workshop and dug around inside couldn’t find anything?!?!, but machine powered up and functioned returned to cx, showed them it working and now it has died again, when we first had it back at the workshop it was also dead
anyone else come across this type of fault
regards
SteveJanuary 19, 2019 at 9:13 pm #460040garn
ParticipantYes iv Had 2 myself. you May have been partially thrown off your diagnosis. during inspection because the way is was functioning, il go through the nightmare of scenarios testing checking.
The behavior of the appliance its working sometimes.
Starts Pumps Works No blockage, Water fills, You Have drum rotation,
it starts washing mixing the clothes up with soap display is counting down, All of a sudden it stops in its tracks, between 3 and ten minutes into the wash cycle .
HA at this point all of a sudden all types diagnosis scenarios are going through your head:confused:
Ok Have A Quick Listen And look to see whether the soap generator circulation pump is working. restart cycle again.
Now before you go and remove the front face of the machine to check the heater and probe because they come into working anything between 3 and 10 minutes of the wash cycle and may stop because they could be faulty.
Get Your meter out and check the input voltage PLUG FLEX 240 volts
after me spending hours on the first appliance fault it took me hours to find this because it was partially working and stopping in its tracks .
Fault THE MACHINE will Spin empty fill Up with waster and start to mix the load ALL ON 237 VOLTS But it wont carry on
its was the blinking sealed plug breaking down not quite enough power to run it 237 volt is got to have 240 VOLTs also the 2nd appliance was the same fault and the plug was hot this time .
Hope this helps and save some time .
Garn
.January 22, 2019 at 8:22 am #460041mickmedway
Participanthi,
thanks for the reply the voltage coming out of the property was 230 and they had experienced problems with there oven as well, I really appreciate the help it was starting to have us baffled
cheers again
Steve -
