DOES ANYBODY KNOW WHAT FAULT CODE 13E STANDS FOR.THIS FAULT CODE APPEARS A FEW SECONDS AFTER PROGRAM IS SELECTED AND START PROGRAM IS SELECTED.THE DOOR INTERLOCK DOES NOT ENERGISE.
Don’t know much about these but sounds like you’ve just solved it by mentioning that the Door Interlock doesn’t energise – Do you have voltage to door lock ? If you do it sounds like the door lock is burgered !
